Passenger Side Mirror
You pull the glass out of the mirror housing. Push it left into the housing, then pull on the right side. It will eventually pop off. Then you will see the mirror motor. 3 torx bolts holding it in. Replace it and put glass back in. Start with right side, then clip in the left. Job done.
This is not definitive that motor is your problem....but likely based on your description.
doctordeuce
09-12-2015 08:30 AM
