Passenger window not working / grinding
The passenger window on my S Type 2000 stopped working. It will some what work going down but there is a grinding noise. It will not work at all going up.
I took off the door panel that and tried to exam the window but there is only a relatively small hole to access the window cable and motor.
I hope my problem is simply that the window cable is detached somewhere but I cant figure out how to examine the system.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
It's not a real big job, takes about a half hour.
Cheers,
Tbird6 told me a window regulator from a Lincoln LS would work for the FRONT windows in an S-Type Jag. I bought it from Amazon for $68.00 and got free shipping!! Here's a link for the drivers door. You need the passenger door so make sure to get the right one!
Amazon.com: Dorman 741-876 Lincoln LS Front Driver Side Power Window Regulator with Motor: Automotive
The crunching noise was the white plastic piece that rides in the channel. They get brittle and break over time. When they do the window cable comes out of the pulley and everything stops working.
Scroll down to read the thread I started about my window problems. There was also a post in that thread with pictures that should help.
I plan to post some pics of my repair. The part was shipped from Amazon today so I should have it soon. From what I read the front window regulators are the same between the LS and S-Type but the rear windows are different so be aware. Also you have to get the correct side as the driver and passenger sides are not interchangable.
If you need information on how to do the job I have it on my page and this is the link Window Regulator I hope this helps!
Were these "white plastic pieces in the channels" replaced with metal parts (or a better overall design) by the 2005 model year? As the S-Type series matured, a number of upgrades were made to fix the original design flaws. I hope that's the case with this plastic window piece. Nothing holding the weight of a car door window should ever be made of plastic. Age, stress, and slamming the doors closed through the years eventually takes its toll on plastic....
As a precaution, our windows are always fully rolled up before we open or close the doors to our S-Type. The more support you can give that glass, the better....
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
