pentosin CHF 11s / 202 power steering fluid
Old 08-18-2012, 11:00 AM
domer94's Avatar
Default pentosin CHF 11s / 202 power steering fluid
i have a few liters of this laying around and coudlnt find a definitive answer on compatibility. can anyone tell me if this stuff can be used in an 05 s-type?
thanks
Old 08-18-2012, 12:08 PM
Jon89's Avatar
Received 4,356 Likes on 2,849 Posts
The appropriate power steering fluid is Dexron III, about four bucks a quart at any auto parts store. Knowing how expensive it can be to replace faulty power steering components, I wouldn't risk pouring the Pentosin stuff in there. Isn't that hydraulic fluid?
Old 08-18-2012, 10:14 PM
domer94's Avatar
i used the atf as recommended in a volvo c70 i had once and it bubbled up badly causing the pump to groan.. i then switched to the pentosin and the system was butter smooth, same with my old 89 saab 900. as far as being hydraulic fluid , i follow the logic that the power steering sysem is in essence a hydraulic system, so it should be ok. i know its quality stuff , so i hate to let it go to waste. i do however, see that people have been using mobil 1 atf whiich is good stuff as well.
sogood
09-15-2015 07:35 AM
bigblackcat3
XJ40 ( XJ81 )
09-14-2015 04:03 PM
1964Daimler
09-09-2015 11:28 AM
MrMellor
09-07-2015 10:22 AM
AL NZ
09-04-2015 08:39 PM
Quick Reply: pentosin CHF 11s / 202 power steering fluid
