Performance Air Intake
You haven't indicated which model/engine you are wanting to "upgrade". Adding your model/engine/production year to your signature line helps us to help you...
I suspect the "hot air intake" remark was a bit tongue-in-cheek, as that is what you will get with the combo you are suggesting. Well, that and K&N oil coating the inside of your intake system, MAF and throttle body...
JagV8 (12-21-2022)
go with the Mina Gallery kit.
its around 7-10 hp gain with a true cold air partition panel . ( if ) you put radiator foam in the rite places .
the J-Pipe you see is custom . .
i believe there is more power to be unlocked by replacing the flat black intake elbow across the top of the engine with the range rover one . someone on here has posts about this .
Vipercf
03-02-2010 03:30 PM
