Performance: Intake improvement
Posted this before but think it needs a separate thread:
https://www.jaguarforums.com/forum/showpost.php?p=223580&postcount=42
I would guess that this could bring 10 to maybe 20 extra horses top end, but it needs to be tested first on a flow bench to be sure that it does deliver.
To make it work, it would need to be precision welded, which I am not able to, however I have the full parts which I am willing to donate if someone can have it tested on a flowbench before and after the inserts that needs to be welded.
This proposed intake modification would be for any STR, not specificaly for a TS conversion at all. I think it could already provide extra power wihtout having to spin the eaton faster, but the more air you are sucking thru the better the effect.
I am still using NGK iridiums however 1 heat range colder for the extra power above stock.
PS For the TS conversion I am contemplating a totaly new intake but that nothing to do with what is proposed here.
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
