performance problem
performance problem
Hi all
i have a 54 plate s type 2.7 diesel. Everything has been fine until last week when I was driving home. Engine was at temp as normal when I went to accelerate no power. Looked down at dash and I had performance restricted
problem being there were no warning lights on anywhere just the message
turn it off and back on it was fine. 8 later exactly the same thing
car had major service and cam belt 4!weeks ago by a local jaguar master tech
no faults on them cars on board diagnostics and I can't get me obd2 reader to talk to the car
any ideas
thamks
paul
any ideas
thamks
paul
I would start by looking at the battery, it has to be 12.6 volts. then I would go to the fuel trims
They might show you if something is not right, The long term fuel trims have to be around+ or - 20% from the 0 line to set a code so if it different from that it may show that you have a problem
Hi,
I use this program http://www.outilsobdfacile.com/software-eobd-facile-elm327.php
Test version.
I set it up to use the graphs in additional features.
then I use the short-term bank 1 ((lambda sensor) long-term 02 sensor bank 1
I also set it up to read the bank 2 at the same time.
watch this video and it help you understand what you are looking at.
https://youtu.be/5WnM_NsOtd8
Test version.
