Pigtail?
Pigtail?
I need, what I believe is called a pigtail, for the auxiliary heater water pump.(the electrical connector)
Here are two links to what the pump looks like.
Cardone Select 5W8005 - Auxiliary Coolant Pump | O'Reilly Auto Parts
Engine Auxiliary Water Pump Dorman 902 407 Fits 01 03 Dodge Durango | eBay
Anyone know how to look one up online?
The original connector will fit the original pump but if you buy an 'aftermarket' pump then you might need to replace the connector with one that is compatible with the new pump.
The 'square-ish' connector on the DORMAN pump will probably be a common Fuel Injector Connector.
Standard Motor Products HP3860
You can splice the new connector to the supply wires BUT make sure you get the polarity CORRECT.
bob
bob
