Pinhole Coolant Leak...help!
Hey Gang,
I have a small leak in the cooling system that I just located today via pressure testing. It's from a plastic housing behind the t/stat housing that the t/stat housing actually bolts to. I'm looking for the proper name of this housing, the part itself, a metal replacement kit, a good way to repair the leaking plastic, or any safe and effective sealers. I'm attaching two photos and please use the yellow dot as a reference. Any help is greatly appreciated.
Having some experience repairing broken/damaged plastic parts in video recorders, basically the best repair is with epoxy resin. You need to be sure everything associated with the repair is clean and well abraided to make the resin stick. If you have a pinhole in a plastic part, make sure there is excess resin above and below the hole. Allow a full 24 hours for the resin to set and keep it warm for the duration. As the pressure when in service is not all that high, I can't see any reason for not giving it a try to save money, but do examine the part carefully for any other unsuspected damage that needs fixing. And of course, full testing when reassembled to be absolutely sure it's working properly.
Leedsman.
Leedsman.
You will need to replace the part. Do not attempt any repair. The plastic has degraded from time and temperature. Any leak you fix now will only last until the next weakest part gives way. A number of people have had these parts leak in various places. When they take things apart it's very common for the plastic to crumble or break further. Look around the part that is leaking and see if any other plastic piece needs to be removed for the repair. Those other plastic pieces might also break when removed. For this same reason used plastic parts would be too big of a gamble. Get new parts from Jaguar.
I agree with tbird6.. You should just replace the part..
Actually the upgraded one is now in Aluminum.. Here’s a link to one I found last night on Ebay for under $50.00
http://cgi.ebay.com/ebaymotors/200-02-JAGUAR-S-TYPE-ALUMINUM-THERMOSTAT-HOUSING-KIT-V8-_W0QQcmdZViewItemQQitemZ160510689362QQptZMotorsQ5f CarQ5fTruckQ5fPartsQ5fAccessories
Hope that helps?
Hope that helps?
Sorry.. Here’s the v6 upgraded one for under $40.00
http://www.rockauto.com/catalog/raframecatalog.php?carcode=1363294&parttype=10337& partkey=2240132&a=FRc1363294k2240132-4039262
Thanks everyone for the follow up. I adjusted my signature to include the engine details. I'm hot on the trail of a new one thanks to everyone's input. The Ebay assembly is for 2000~2002, mine's a 2003 4.2 and my t/stat comes out at a right angle from the t/stat housing. The Rock Auto ones show the hose outlet coming straight out so I have Rock Auto talking to URO parts to see of the photo's are accurate or generic. I did locate an assembly through JAGBITS for $99.00 but not sure if it's an aluminum update or oem. Thanks again all and I'll keep you all posted on the outcome.
Here's the only site I found so far that has exactly what I'm looking for. Just look at this contraption...YIKES! http://www.britishparts.co.uk/.sc/ms...-%20THERMOSTAT They do have a reasonable price though and I'm waiting for a response on shipping costs. More updates as they roll in.
Okay, I purchased the par from here http://www.britishparts.co.uk and they were fast and reliable. I ordered it Monday evening and received it to North Carolina on Friday afternoon.....same week! and the price was cheaper than anyone here in the States without shipping. It came to about $80.00 w/shipping. I didn't install it yet because I decided to get a new serpentine belt w/idle pulley and bearing, why not since I'm there. I purchased a JTIS CD (repair manual) from Advance Auto Part here in town and it's time to dig in and see how to open this S.O.B.......not as easy as one might imagine. I have Windows XP so if anyone has a complete, easy to understand, step-by-step instructions on how to accomplish this feat, please let me know. BTW- I'll be sharing this repair with you all as I go through the procedure, be patient, I'm getting there. Oh Yeah, I did read the "Read Me" as stated in the CD and I get to chase my tail because it says I must close a file that ADO is running in and it does not exist. Thanks for any help.
Received 2,193 Likes
you need intake gaskets too since youll have to remove the intake to replace the housing. DO NOT try to reuse the intake gaskets, theyre stamped metal and will leak vacuum.
these thermostat housing parts ARE NOT YET avail in metal. that earlier link is to the 4.0 not the 4.2
I'm so sorry Bob but I don't. You see I bought a JTIS CD (service Manual) from Advance auto Parts and I cannot get it to open in spite if all my efforts. I'm waiting to hear back from him any time now with regards to it being a bum CD. Then a member wrote me and said I need intake gaskets to accomplish this task, more back up time. Then I said what the heck, I may as well replace the serpentine belt and idle pulley while I'm there so here I am holding my......whatever while all the stars line up. I don't have a garage so I have to work on it at work which is a automotive technical school, big plus there, but I can't have it tying up a stall, in case something goes wrong. The biggest hold-up is the Manual because I don't want to dig into it until I have that. I really don't think it's going to be a big deal though, always think positive. Sorry again.
[quote=Bob Smith;288280]No worries at all, I totally understand.
I had some issues getting my JTIS CD to work on XP... I can't remember exactly what I did to get it working, but it wasn't intuitive.
I'm gonna have the dealer do it as I just don't have the time this week... best of luck on your fixes!
Same to you Bob, thanks
