Places to buy engine internals
Hey everyone, new to the forum and my first post. I've been looking around here for about a week now and finally decided to join
I've been looking for a Jag for a while now and have come across an '01 S type with a knocking 4.0 engine. I'm pretty knowledgeable with cars and have done engine swaps and a bunch of mechanical work, but it's all been on my '04 Mustang.
If I bought this I'd tear it down and probably rebuild the bottom end... the only problem is that I can't find any good sources/places to buy internals for the 4.0 that's in the S type. I wouldn't know until I got into it, but I'm planning on possibly replacing crankshaft, rods, pistons, all the bearings and seals, etc. There are tons of online sources for Mustang stuff, but I haven't been able to find much for the Jaguars. Can anyone direct me to a good source for this stuff?
I think Federal Mogul makes rings and maybe pistons for the 3.0, but I can't find anything for the 4.0 I don't need any forged internals, I'm just looking to build this S back to stock specs (which is still pretty good power IMO). I've looked in the stickies and the FAQ's but the only decent thing I could find was Racing Green, but that's in England so I didn't know if shipping would be ridiculous.
Thanks everyone!
Thanks everyone!
i may be wrong but you can't get any , over size bearing shell's or piston's etc
read this it may be of use
http://www.racinggreencars.com/moder...J-V8Engine.pdf
I'll check with the European motors dealer/servicer by me but I would think anything from the dealer is going to be more expensive. I don't go cheap on projects, but a lot of times you can get the same part (same manufacturer and everything) at a local parts store or online for much cheaper than the dealer. I know there are a lot of things that you kinda HAVE to get from the dealer because it's a Jag, but I was hoping other places would carry the main engine components.
Sorry for the double post, didn't know it was frowned upon here. Thanks for the heads up!
I'll definitely check into that. I hope plugs like that are allowed because that's kinda what I asked for lol I guess if Napa has them it'd be worth asking around at CarQuest and O'Reillys too eh?
On the same webite you linked, racinggreencars.com, you can get oversized crank and big end bearings
http://www.thejaguarshop.com/Jaguar/...wards/c%7C.htm
You may be right about the pistons and rings though. Someone said that local parts stores (napa, carquest, etc) carry rebuild kits for the 4.0 and you can get a .030 kit so I dunno. I'm going to do more checking this weekend.
I'd guess some of the forum sponsors would sell a kit or just a list of parts if they knew you wanted them. Be sure to ask them. I don't think your kind of request occurs here often (or at all?) but most of us really couldn't attempt a rebuild like that!
That said, I'm definitely interested in what you find out, pictures of the rebuild, you name it
And I guess I'm not the only one.
I cant speak about the other companys, but I work for GPC which is the parent company of NAPA so I got curious and we do have short blocks long blocks and full engine kits, (pistons, rings, bolts, bearings,seals, gaskets,etc...)
jagV8 (or anyone else), what sponsors do you recommend I talk to?
And not to sound ignorant but you guys and gals around here don't build motors very often? I tried searching around the site for engine rebuilds and stuff like that but couldn't find much. I was hoping I wouldn't hop in here with this question and be "that newb" that asks the question that has been answered 1000 times :P
Thanks for the quick responses everyone, keep them coming! I didn't realize these boards saw this much activity, I'm pleasantly surprised
Hmmm you've got my mouth watering now. This might actually be a possible project. I would absolutely love to get into an S Type
All the 4.0 V8 engine blocks are the same with some differences in the oil pump/pickup tube later engines 2002MY>. The sump plates and lower sumps are specific to each application (AJ26,AJ27,AJ28). The cylinder heads are mostly compatible ('A'bank AJ26 has no VVT sensor). The can of worms you are opening is complicated. There is a stamping on the side of the block for piston/bore, crank/block, crank/journal dimensions. The bearing selection is a matrix with a color coded and numbered parts list. I had a discussion on this topic with a forum member several months ago. I suggest a search or get a copy of Jaguar V8 Engine Training Course 180 or V8/V6 Training Course 168. There might be an aftermarket generic rebuild kit but I have never used one.
bob gauff
bob gauff
