Plastic Part?
Many of these original high failure parts have been replaced by metal ones; as even Jaguar acknowledged that plastic was a poor choice to begin with.
Last edited by Warspite; 11-22-2015 at 10:19 PM. Reason: Spell Check is your Friend.
The plastic thermostat housing is indeed susceptible to warping, cracking, and leaking. The leak in my wife's XK8 exactly one year ago resulted from a warped thermostat housing. I nailed it down with a pressure test kit loaned from Advance Auto Parts. After doing the research on the XK8 forum and getting good advice from other 4.2 engine owners, I opted to replace the entire black plastic cooling outlet duct assembly and be done with it. No issues since....
No. You utilize the appropriate cone-shaped adapter from the pressure test kit that fits snugly down into the coolant reservoir (after removing the reservoir cap) and pump it up using the kit's hand pump. Your leak will become obvious (and usually enlarges) pretty quickly, so park the car where you plan to effect the necessary repairs before you perform the pressure test. Once you've done the pressure test, it's a good idea NOT to crank the engine again until you have completed the repairs....
Dennis Catone (11-25-2015)
Audiguy
01-07-2016 06:16 PM
FS[NorthEast]: 1995 Jaguar XJR For Parts or Refurb - Western MA $1200
95 AJ16-5
11-20-2015 11:34 AM
WTB[Canada]: X300 sunroof cover + minor parts
Malihide
11-17-2015 12:55 AM
WTB[SouthEast]: Jaguar Mark IX Parts Wanted
jimateo
11-15-2015 08:13 PM
