Please help! 03 STR tranny slips when I give it a lot of gas
Hi my extremely well maintain 03 STR the tranny slips when I give it a good push. Normal driving not issues if I hit the gas hard to try and pass someone it's slips. Thought maybe was low on fluid because I had a leak. It changed at 76k guy said it wasn't that low maybe half a quart and it looked new no smell and very clean. Also giving the code for transmission range sensor. I call jag they don't have that part for this car, they say everything is inside the tranny. So my guy is telling me I need a new tranny. In my gut I really don't think I need a tranny at 76k miles when car has been so well maintained. Called a tranny guy gave him the code he said he thinks it the gear select box. When I drive it flashes some code but so quick I can't make out what it is but is says perform or performance something. Also I don't know if this means anything after getting fluid changed none of my windows worked so I turned car of and on and they worked again. My remote control also didn't work at first. Then it would just lock and not unlock then again after a few tries works good again. Has anyone ever had this issue or have any idea of what it could be? I just don't want to spend tons of money on a tranny or a gear box selector and then end up with the same problem. Thank you guys so much in advance for any help or advise you may have!
P999l (10-02-2015)
Received 2,263 Likes
P999l (10-02-2015)
Your mileage has no impact on your battery's condition. How old is your battery? Find the date stamp on it (XX/YY where XX means month and YY means year) and let us know. These cars consume tons of electrical power and any battery more than three years old could be suspect. Some batteries have been known to begin failing in just a year or two....
P999l (10-02-2015)
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
scottatl
09-04-2015 08:08 PM
