PO174 reading....need advice
Received 2,675 Likes
The code is P0174 and a vacuum leak is the most likely cause. Fuel trims will help confirm this as well.
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Next, you should do a search on the Jag Forum for code P0174 (it's a zero, not the letter "O"). There are lots of threads on this code. As mentioned above by one of the most esteemed members of this forum, it's most likely a vacuum leak, as it was on my car. Relatively inexpensive to repair, but you MUST start by knowing exactly what MY and engine you have.
NBCat (02-18-2015)
The following 2 users liked this post by joycesjag:
Jumpin' Jag Flash (02-25-2015),
NBCat (02-18-2015)
Yes....it is a 4.2 L Where can I find a diagram of all of the vacuum lines to check. I tried last nite but was unsuccessful in finding a leak. Perhaps I just haven't checked the right one. I heard that some models must be checked with propane and not carb cleaner. Any truth to that??? I cleaned maf sensor and checked all connections that I could find by spraying cleaner but I feel like I might have missed some. Thanks for your help
Most competent repair shops can perform a smoke test and locate vacuum leaks quickly if you do not have access to such equipment.
mikiep
12-20-2019 07:37 PM
