Porous Transmission Pan
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Hello, All,
On a recent recent oil change visit with my 2007 S Type, my Jag dealer imformed me my transmission pan was beginning to leak. I asked if it was a gasket, and he stated the pan is a composite material which seeps over time.
Repair estimate is $1238.00. I see pans and gaskets all over the web cheap.
Am I getting a straight story from this dealer?
Paul Brown
Paul Brown
mate,
Check through the forum, the pan is a combined pan and filter and the recommended change (with oil and the mechtronic sleeve) is 60,000 - 100,000km.
I did mine a few weeks ago for a cost of about AU$600 (US$550) using the top quality Lifeguard 6 oil. It should take you about 4-5 hours the first go, probably a little quicker after that.
Just for the pure comic relief, I did get a quote from my local Jag dealer, wait for it... $4700. $1000 of that for the oil alone!!!
If you can swing a spanner, give it a go. There is a good thread in the S-Type stickies which will tell you what you need, where to get it and how to do it.
https://www.jaguarforums.com/forum/s...ics-faq-30991/
Good luck...
Good luck...
Can I strongly recommend having some spares. They torque in at 8NM and shear off at about 8.1NM. Took me two days to extricate the remaining piece and replace...
I used 10 new bolts out of 24 as some rounded of removing and most required the gentle persuasion only a cold chisel and 10lb mallet can provide.
Cheers,
Cheers,
