Is it posible to reflash the computer for performance upgrades?
The kind of aftermarket options you're thinking of, simply don't exist off-the-shelf for the S-Type / STR.
You would need to seek out a professional and competent tuner shop / fabricator in your area for a more specialized approach to your direct car/build.
Here is an example of one shop doing some very nice work in this regard, that recently posted this thread in this very section.
https://www.jaguarforums.com/forum/s...%2A-%2A-80590/
They have not found a 'tuning' solution yet either, and are likely going standalone.
On top of that, paying someone else to do the pioneering and custom one-off work, ends up making something like this into a VERY expensive project.
The most practical and cost effective upgrade that you could do is to step up to the 'R' model S-Type. At that point, you can do a few simple bolt-on modifcations to really get the most out of it.
If that still isn't enough, you may want to consider moving onto a better/newer platform for your goals.
Candy's Kitty (09-18-2012)
S-type "R" up grade
Ok. Say I do this upgrade what needs to be done to convert it? If I'm going to do this it would probably be a good time to so some internal mods. Do you or anyone you know have any suggestions: cams, cam gears, rockers, valve springs, pistons, etc.
Also any shops in LA/ SoCal area. I'm not trying to break a nail.
Received 2,263 Likes
If you want BIG power, an STR is not the route to go. I would go with the V8 that you already have and find a shop to turbo it for say $15-20k, probably more considering it will be all custom and hope its reliable. With the STR, putting every available mod on it still won't get you to 400whp without nitrous. Other than that, you could look into an engine swap or just get a different car.
What goals do you have in mind?
The following 2 users liked this post by Cambo:
Candy's Kitty (09-19-2012),
Panthro (10-20-2012)
Actually, they are probably safer then the street versions... but not up to the "comfort" standards you are looking for.
Those cars you pictured are reinforced unibodies with their own electrics and power train; loosely based on the original car. And depending on the class rules, may very well not make much more power then the original car..
It's easy to gut and build... Heck I could scan a picture of the F150 we used to run in mud racing and I bet no-one would be able to tell what frame it rode on (S10 Chevy BTW).... Welding / Tubing / Cutters and no pesky motor vehicle laws and you can build anything..
Oh, if you want to make big power on the cheap in a rear drive sedan 'bout the only choices out there are a Pontiac G8 or one of the Chrysler/Dodge LX cars. Anything else is going to need VERY DEEP pockets as others have said.
Oh, on another note... LOL... I have a couple of those S Type V8 Star 1:43 diecast sitting on my shelf....
the teal/green one has been tuned and is running speed density so it's probably an aftermarket ecu or tune in it. There's no mass air sensor on it.
If you're in LA, you're screwed like me. There's no way to tune them and no cost effective way to mod them. The natural answer is LSX, but without doing the work yourself, you're up the creek unless you have at least $20-30k to put into the car. Everything will need to be custom and fabricated.
You could go compound boost on a s type r model and use the existing ecu with a turbo feeding the supercharger, but you'd still have to spend at least about $10k to get there.
If you want to fast, don't buy a jag(unless you have deep, deep pockets).
scottatl
09-04-2015 08:08 PM
