Possible source for lower s type rear bushs
Old 02-25-2013 | 09:34 PM
mikewv100's Avatar
Default Possible source for lower s type rear bushs
I have been looking for bushes for the rear lower control arms for my 2003 s type 2004 for all intents and purposes. I came across this site that I have never seen before. Does anyone have any experience with these. The bush sizes work perfectly. At this price compared to 500 plus per arm, does this not make sense?
S-TYPE e XJ Rear lower control arm silentblocks - SILENTBLOCKS
Old 02-26-2013 | 10:16 AM
Robinb's Avatar
Interesting - I am always looking for sources of suspension bushes.
I see that only 14 mm internal diameter is available - wonder if that would be OK for my '05 STR. Anyone know?
Old 02-27-2013 | 08:05 AM
mikewv100's Avatar
I ordered a pair for my base. I have an extra pair of old arms laying around to make easier. This would be great. If the difference in the 14 and 16 str, I know for sure the base is 14. Unfortunately probably 16 is str. Might send them an email and see if they vill make them. I will let you know if this works.
Old 02-27-2013 | 08:44 AM
PhilT's Avatar
Default STR Bushings
My 03 STR has developed a intermittent creaking sound when the front suspension is depressed ( braking) or rises. Thinking at 98k the suspension bushes are done. I know that the STR lower control arm are different from the base mode. guess I need to finally buy the JTIS and check the parts numbers and rent /buy a press.
Will be searching for a bush kit..any sources other than the local Jag dealer ( who does not like my 10 YO iron) would be appreciated.
BTW looking for a nice Mk II, 3.8 or conversion with ac as a frequent driver..
Phil
pwtrusty@yahoo.com
Old 02-27-2013 | 10:15 AM
tbird6's Avatar
If you are talking about the 14mm and 16mm issue that's the diameter of the lower ball joint shaft. Nothing to do with the bushings.
In 2002 Jaguar/Ford upgraded the S Type and the LS to 16mm. All STR's have the larger size.
Robinb (02-27-2013)
Old 02-28-2013 | 08:34 AM
mikewv100's Avatar
I was referring to the rear suspension. Have not had to go to front yet
Old 02-28-2013 | 08:48 AM
mikewv100's Avatar
I have a 2003 late base and the center hole is 14 mm. That is the size bolt that goes through the center of the bushing.
Old 03-05-2013 | 02:16 PM
jagfanfan's Avatar
Default Found S-Type bushes
I've found the site silentblocks.com, they have almost everything I need but I would like to have any feedback about them first.
Somebody??
Old 03-05-2013 | 02:41 PM
JagV8's Avatar
Never seen anyone post on them. It could be you...
Old 12-31-2013 | 02:40 PM
Londonjagowner's Avatar
I'm reviving this thread - Anybody care to update on this?
Old 12-31-2013 | 03:17 PM
clubairth1's Avatar
Looks like they have a wide selection but nobody on the list seems to have used them. Maybe they don't sell into the US?
Old 12-31-2013 | 04:54 PM
Lt0302's Avatar
Default I have a set available
400 bucks shipped CONUS and it does both sides 2 large bushings and 4 smalls ones, 6 total for the rear lower arms. I have used a set on mine that I did last month so far so good! Mine is a 05 S type with 4.2 NA. Only have 1 set available!
BrentGardner
28
04-26-2024 04:08 AM
Fraser Mitchell
10-01-2015 05:06 AM
stanjag
08-30-2015 11:35 AM
Doug Dooren
08-30-2015 09:51 AM
BierNut
08-28-2015 10:22 PM
Quick Reply: Possible source for lower s type rear bushs
