possible timing issue
Old 04-22-2015 | 07:22 AM
NBCat's Avatar
Based on the sound in this most recent video, there may be a bent valve.
  #42
Old 04-22-2015 | 08:02 PM
seagates5's Avatar
Ugh..I was afraid of that. I was going to check the valve lash to see if they were out of spec
  #43
Old 04-24-2015 | 03:18 AM
seagates5's Avatar
I checked all the valve lashes and they all were consistent and within spec on all except the driver side intake valves
  #44
Old 04-26-2015 | 07:57 AM
NBCat's Avatar
If you do indeed have a bent valve on the LH (Bank2) cylinder head, the engine must be removed from the car as the head on that side cannot be taken off with the engine in situ.
  #45
Old 04-27-2015 | 01:15 AM
seagates5's Avatar
Ugh...They should have put that in the JTIS, thats good to know
  #46
Old 05-02-2015 | 04:28 PM
seagates5's Avatar
I had a dry and wet compression done and it indicated that the piston rings are worn. The dry compression was 90psi and after the squirt of oil it went to 130psi on the first cylinder of the LH bank
SD96XJ6L
01-12-2022 04:30 AM
Rupesh
03-25-2016 03:33 PM
X_Type_South_Africa
12-09-2015 05:37 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Jandreu
08-29-2015 07:31 PM
Quick Reply: possible timing issue
