Possibly Clogged Fuel Filter?
Hi Everybody,
I'm here for help again. I was a bit low on fule 1/8-1/10 of the tank. Shutdown my car just fine, turned it back on it gave some weird strong jerks. Turned it off, tried again same thing, did it again and same thing kept it on for a 15-20 seconds and after a lot of jerks engine shut of again automatically. So seems like everything was working fine but engine is starving for fuel. Brought some Gallon gas and poured in the tank. Started again but the same problem.
Now some times car starts but turns of after some jerks are trying hard to be smooth.
No engine light or what so ever. Fuel light was not yet turned on. (I drove even in Fuel Light on 2 times before without any problems). I can also hear fuel pump making some noise.
Ran and brought Fuel Filter. I think as fuel tank was low so some particles and garbage had clogged filter?
Going to put the new filter tomorrow to see if makes any difference.
Do you guys any suggestions to check/do besides putting the new fuel filter?
Thanks a lot for your time and answers.
Best Regards,
Rizwan
Best Regards,
Rizwan
Hi Everybody,
Best Regards,
Rizwan
Best Regards,
Rizwan
There is a video in my youtube channel in my sig for fuel filter replacement just in case you need it.
Yes I did 5 Gallon Already but no success in only doing that.
Did this too as I said car starts but it stalls after some jerks...
I don't think so as I wrote I have gone much lower before than today without any problem.
Lets hope but I think thats making some noise (probably trying to fetch fuel)
Millions thanks for that one as that video gave me confidence to go get the fuel filter and see what happens.
I'll try that tomorrow and post the results.
Thanks a lot for your valuable suggestions.
Best Regards,
Rizwan
Best Regards,
Rizwan
OK Here is what solved my problem. (Thanks vance580)
Changed the Fuel Filter.
Man the side which was coming from Fuel Tank had a BLACK fuel in it. But filter seemed to be doing good job.
The car didn't start at all after changing the fuel filter.
Checked the fuses and found:
F47 15A Rear electronic module, fuel pump driver .
was bad.
Replaced it with the new Fuse and car started just fine!!! (Thanks to my friend Mike who did help me with all this)
I have a question though.
Can we flush the Fuel tank and make sure whole junk is sucked out of tank leaving it clean?
Thanks for the inputs.
Thanks,
Rizwan
was bad.
Thanks,
Rizwan
I'm glad it's running again.
Not easily. You'd need to figure a way, probably not using the existing fuel pump(s) (they're driven via pulses, don't think you can just hotwire them) and probably opening the lines somewhere. Maybe remove the tank.
You must excercise great caution when doing it this way, and use common sense, and more importantly a pump rated for fuel, Matco, Snap On and other companies have pumps deisgned for this duty.
you can either use the filler neck going into the tank or use the access hatch under the rear seat after you remove the pump.
Also no smoking while the tank is open, no sparks, open flames, use a respirator.
Legal disclaimer: This is only advise on how it can be cleaned out this is no way shape or form the absolute guide to doing this job. I will not be held responsible for anything that happens steming from this advise. Reading this post is an acknoledgement that you agree not to hold me liable for personal or property damage that may occur.
Thanks for the great information though.
Best Regards,
Rizwan
Haha no problem it can actually be done under a carport the most important thing is safety drain the tank into gas cans and while you have the pump assembly out of the tank change the fuel pump socks while you have out. And pumps if you have the cash to spare. Remember they are motors and they wear with time so might as well while your in there
I was expecting Such a reply so that fine for me.
Yes, I believe JTIS but I was just wondering (With no/little knowledge of cars, I was thinking that every car has Metal Tanks).
I got amazed and that's why I posted that.
But that doesn't stop me from being curious and learn more. And that is why this forum exists.
Sorry for making you mad though.
Thanks for your answers![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Rizwan
Rizwan
aholbro1
08-05-2021 05:02 AM
