Power seat troubles
Hi all. I have a new to me '02 s-type 4 liter and I'm having trouble with the power seats. No controls for the driver side are working except for the lumbar. I've checked all pertaining fuses and all are good so I tried contact cleaner on the switches but still no go. I cleaned all the connections to the motors and the seat module but that still didn't help so I'd decided to swap seat modules with the passenger side to see if that was the cause, but realized that the passenger side has the same problems. No controls work except for the lumbar, which I believe is on a separate fused circuit. Could this be a bad driver door module? Both mirrors and all windows are working and from my research, I think the door module controls those too. I'm not sure where to go from here and any advise would be appreciated.
I would first disconnect the seat from the body (4 bolts) tilt it so you can have access to all the connectors under the seat to ensure they all are connected and snug...
Regarding the lumbar - either the bladder bag could be shot or a loose connection. The odds of this happening for both seats is remote at best.
What color are your seats? FYI - cleaning out my garage and putting a set of front seats from my 00 S-Type up later.
Hi Spiralout
Hope this helps I have changed the seats in my car for the same problem. I found out after it was the spiral device which the seat is wound back with and if your long in leg like me I had to have it full way back This apparently jams the works, as it comes to a stop at the end of the Archimedes bar and jams. I made it work once by operating the switches and jumping up and down on the seat. However I had to change in the end. If you take it back fully then come forward a little and save the setting you should have no further problems. My seat has been working for many years now trouble free.
