power steering fluid
ianw48 (02-13-2016)
ianw48 (02-13-2016)
Received 2,263 Likes
ianw48 (02-13-2016)
The following 2 users liked this post by aholbro1:
Grant Francis (02-14-2016),
ianw48 (02-13-2016)
The following 2 users liked this post by Mikey:
Abby's Guy (03-04-2021),
ianw48 (02-13-2016)
ianw48 (02-13-2016)
Ian, one caveat I would add is if this 2003 S is "new to you" having been recently obtained in the used-car market, I'd change it right away! You don't know what manner of elixir the previous owners may've dribbled in there. Chances are it was maintained with proper spec. fluids, but unless you can confirm that for certain, you'd be better served renewing it. (also a stated practice of whoever it is I remember reading...and a sound one, I think, though I'm guilty of not practicing it immediately upon purchase, always)
The following 3 users liked this post by aholbro1:
One of our members here, I believe an Aussie or NZ'er, maintains a habit of renewing ALL fluids every 2 years. Claims it has never presented a problem. I "think" it is Grant, but don't recall exactly. (I'm sure he's an X300'er, but seem to recall he's also got S-types in the stable)
I change all the fluids every 2 years, except teh engine oil, it is HABIT, and I have NEVER had a component failure because of it.
The X300 and the S Types are simple. Syringe out the old at the container, refill with new fluid, have a beer, turn lock to lock 3 times (no idea why), syringe it out again, refill, more beer.
Take spouse for a drive, you are done.
The V12's are a tad messier, coz that Saginaw pump is sort of "down there somewhere", but 2 years again is my ruling.
I use Penrite PAS in the S Types, and Full Synthetic Trans Fluid in ALL the others.
The following 3 users liked this post by Grant Francis:
With any used car at that age. I change EVERY fluid in it as soon as I buy it.
No one does any maintenance these days so it will be needed. Plus you really should inspect any used car from top to bottom as soon as possible. Many things will come to light and you might catch something before it causes bigger problems.
Example I just purchased a 2013 car with only 24K miles on it. Certified Pre-owned by the dealer. 200 point inspection from top to bottom!
I got it on my lift and the drivers side rear shock was dripping fluid. That car has electronic suspension similar to the Jaguar CATS system. So the struts/shocks are over $600 each. Very good catch and the dealer replaced it.
But it was so obvious that I have to question if the dealer even looked at the car? I think the answer is they did not and just hoped for the best. After all if the customer did not bring it back to complain they would not have needed to replace that very expensive shock/strut!
The following 4 users liked this post by clubairth1:
Agree 100% on that.
Had a few of them over the years, the stamps in the service book are just that quickie "warm and fuzzy", that quickly chills.
As soon as I get the new toy home I do the following.
Drain everything drainable, and refill with the latest spec fluid available.
New hoses, coolant that is, and I mean ALL.
New drive belt/s.
New brake hoses, and pads and rotors.
New battery, unless there is a receipt that verifies a new one in the last year.
So an and so forth.
Never had a let down yet, and I have had MANY Jags. Gladly my kids follow the old man, and do the same.
New drive belt/s.
So an and so forth.
ianw48 (02-15-2016)
annamiata
03-22-2016 08:03 AM
