Power steering pump - After Market won't mount
2001 Jaguar S-Type, V8
The pump went out (so the mechanic at Pep Boys told me---after replacing the Rack and Pinion---yet pump was working fine beforehand). Anyway, the pump went out, and all the pumps (up to 4) ordered by Pep Boys from local parts stores, won't mount to the block (I guess the block).
Does anyone know where I can get an aftermarket power steering pump that will fit, rather than paying $640+ to Jaguar)?
At this point, is it possible you can find a used one from a local breaker's yard?
You may also find a remanufactured unit on the Internet.
After the mechanic installed the Rack and Pinion (and Like I said, it was working fine before---had the R&P changed out because they would not simply change out inner tie rods (pax side was supposedly bad---so the mechanics said)), they released the car to me without mentioning the power steering malfunction. I say, malfunction, because when I picked up the car, the steering was very hard. I returned it to them and they claimed it was like that when they got the car (a lie). So, the 'went out' means that the steering instantly became hard, unlike it was before I brought it to them. Unfortunately, the primary reason I bought it to them (on a trailer) was to diagnose a 'non-starting' issue...when they claimed (and repaired) it was the fuel pump. In retrospect, I believe it was only the fuel pump fuse (they had to change the fuse after the first fule pump they installed didn't work, and ordered a second).
SO, BL---think I'm getting the shaft (not just a fuel pump, power steering pump, and labor for those installations and the R&P)!!!!
Just wondering if there is something UNIQUE about the pump for this car that the AM versions can't seem to match.
Aren't you always on here saying how cheap these cars are? Now you are bashing members for taking their 13 year old, <$5k car to a chain repair facility? How about offering a real suggestion instead of snide comments like you seem to do in almost all of your posts?
Thanks, Quartz.....was surprised to see such a comment myself.
Check out www.rockauto.com - As other members mentioned - the LS power steering pump should be an exact fit.
rusty37
04-05-2020 07:40 PM
Dicque
09-19-2015 12:53 PM
