Power Steering shudder
Engineer there was some talk about an additive that goes in the power steering reservoir that Jag has. It does away with the shudder, cooing, and "column noise". I will look for that thread.
Found it:
https://www.jaguarforums.com/forum/s...steering+noise
Found it:
My 03 stype has the 'shutter' as well. I had the Jag Shop in Portland, Oregon do the steering additive a month ago and it completely got rid of the annoying noise but the hudder remains. Asked the technician and he said, it's annoying, but the additive will not address the shudder. The bushings would need replacement, if you want that totally removed. I asked if it was safe to drive and he said, sure, no problem, but it is somewhat annoying. It only does it when I turn the wheel to the far right or left quickly.
So, have the same shudder symptoms. My mechanic diagnosed as a system leak akin to a fluid leak except the leak sucks air in to the system. A new rack and steering box installed right around $2K and still have the shudder. Talked to the dealer and they said all the lines should be replaced. I f that doesn't do it then the reservoir would be next. Really? I'm not sure my warranty company or my funding resources are able to do the "keep throwing parts in til it's fixed" approach. Any thoughts?
1964Daimler
09-09-2015 11:28 AM
