Power to window switch problem
The windows on this car work well with the master switch. Up/Down with not problems. The local switches on all the doors do not work. Somehow the power is not going through the switch. I replaced the master driver door switch and there was no change on the other three doors. I checked all the fuses and I have the diagrams, but I keep thinking it must be something like a plug that is loose or a system bus that would control this. Any ideas would be helpful. The windows worked when I first got the car and hardly anyone rides in it so I don't know when this started. PS: I reinstalled the original master switch.
Thanks.
Thanks.
Could be a module problem... modules control everything on these cars....and if I remember right most things have constant power and the grounds are switched....maybe even simple as a bad ground...i think there are about 10 of them in different spots......if Karl chimes in he will know...or Jagv8
I wouldn't rule out a broken wire in the driver door post-to-cabin wiring loom. Normally, the one that breaks disables all windows from all switchers. However, my vague recollection of tracing the wiring when I had the problem was that all power to the door switches runs through the master switch, so perhaps you've got a different broken wire than several of us have had?
weisberg
05-13-2014 10:12 PM
WTB[LowerAtlantic]: Power window switch - 2000 XK8
datuttle
03-30-2014 06:20 PM
