Pre ignition noises
My car work better when the weather is cold, so my str running fine about 10 minutes, then begin to loss potency, making sounds "cascabelear" (spanish) like when the gas is in low octane (pre ignition), lower gas mileage. However is no overheated & no codes.
2 months ago had a burn head gasket, that was replaced tensioners & guides, no chains was replaced...
I asked about that a mechanic... (no jaguar certified) He said think the motor no have enough antifreeze, that need to purge it, I did but nothing change. I thinking about radiator fan problem, because the second speed is not working (I think so), I'm put the A/C on maximum and no change to second speed.
Thank You guys for u interest
UKnFor-dluv-expat
09-26-2015 08:40 PM
