problem with 2001 s-type 4.0
Old 02-28-2012, 10:24 PM
chootem's Avatar
Originally Posted by chootem
If i remove the battery and take it to a autoparts store with a battery load tester will that tell me if its a bad battery or not?
Originally Posted by JagV8
No.
That has been posted many times.
i was just told that i couldn't test the battery like that.......but if i can i definetly will. But a slightly new question the electrical connections going to the the injectors fire the injectors right? so if i unplugged them it would change the way its running correct? I unplugged 3 separate injectors and no change. and they were on cyl i wasn't having problems with......now i was having a problem with the engine shutting down but has since stopped having that problem....... could these injectors be stuck open?
Old 02-28-2012, 11:11 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
You said no spark. Well, I guess you did not like what I recommended for you to do.
chootem (02-29-2012)
Old 02-29-2012, 12:57 AM
JagV8's Avatar
Received 4,534 Likes on 3,943 Posts
I give up.
Old 02-29-2012, 03:40 PM
chootem's Avatar
I am going to check what you recommended. i appreciate your help
toronadomike
08-07-2022 03:41 PM
Sprayall
05-30-2021 08:13 AM
Dicque
09-04-2015 12:50 PM
Sprayall
09-03-2015 07:49 PM
Bowman
09-03-2015 03:17 PM
Quick Reply: problem with 2001 s-type 4.0
