Which pulley is last one for installing drive belt?
I believe John is correct, it shouldn't matter if you've routed it properly.
I've always found it easiest to do the power steering pump pulley last....but I never try to R&R the belt without first removing the air box.
Are you sure in matching up new pulleys you didn't end up slightly oversize on both? Seems I saw in another thread you were replacing two. If that is the case, you might try the belt for an 05. Many places list the same p/n for both but I once got my stock mixed up and came short on the 05....found out I was attempting to fit a belt I'd ordered for the 03. Think the 05 spec is a few mm longer...
switchgod
02-04-2016 08:11 PM
Jennifer S Flavell
02-04-2016 05:13 AM
