Purpose of Connectors in Trunk
Received 2,192 Likes
Interesting that they would go to the expense of putting in the wiring harness for the electronic shocks when it was only an option on my S-type (I believe it was standard on the R models and with the Sport package). From your reply it sounds like the replacement electronic shocks are quite expensive.
George
It's probably part of the main body harness.. It's probably more expensive to get the OEM wiring harness manufacturer to make multiple harnesses with different connectors, etc and go to the trouble of having to install specific harnesses in specific cars based on what options they will be built with. Much easier, more efficient, and probably cheaper to have one universal harness and leave a couple connectors dangling in cars not fitted with the option.
George
George
theyre expensive and Ive never seen them other than a dealer. I have converted more than a few to conventional when the electronic go bad. I can replace all 4 for the price of 2 electronic
George
George
But here is another little tidbit....They do change things, mid-production. Example....Wanted to change the power window switch on my Accord because the drivers side was worn. Had an 05 but got a used switch from a 04. It didn't work because they had changed the connector. Checked with Honda, and it was two different part numbers. Actually took the switch apart and combined the new mechanical top part with the old electrics since the old switch did work fine.. That is just another example of "always check the part numbers" . Even if it looks the same it may not be the same...
Hey Jeff,
Any chance you could source the female side of the connector for the Alpine amplifier..
One of my friends went to the trouble of desoldering the connector off the board of the alpine amp to make a harness. - But if we could find a female, we could plug in adapter harnesess for the factory wiring and in turn leave the car's wiring intact, yet still upgrade the "premium" audio systems.
George
George
Hey Jeff,
George
George
