Question about DTC P1000 after battery d/c
After my plug change and installing Mafioso's Intake I did a hard reset. I plugged in my code reader and it pulled up P1000. I did some searching around on the forums, and its due to incomplete of drive cycles. Does this go away by itself or do I have to perform a series of tests like on page 3 using the diagnostic guide pdf attached to this message.
Thanks for all your suggestions.
LOlz.....I miss the cold weather already, its starting to burn up here in the 90's already. Yea FL, is pretty much laid back, do whatever you want with your vehicle except have blue or red lights
, So basically you guys just suggest I drive and it will go away instead of doing the drive cycles as mentioned in the pdf?
Thanks amigos!
![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
Thanks amigos!
Thanks amigos!
Thanks amigos!
jag79 (03-26-2011)
trosty
26
12-18-2022 06:40 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
