Question on optional packages
I just got the Monroney sheet for my car. Very cool. Now I can read the sheet in fond remembrance whenever my wife takes the Jaguar to work. Given that it is a 2005 S-Type 3.0, I have two questions.....
1. What is the "Preferred Premium Package" with a price of $3000?
2. What does the "Cold Weather Package" consist of other than the heated windshield?
Curiously, I'd always thought the car was originally destined for a colder climate and just diverted into Miami. This shows Miami as the original destination.
Eric
Eric
I'll pull up the option sheets I have for the 05 when I get home and post them. In a nutshell the cold weather pkg gave you heated seats and the premium pkg gave you goodies like homelink, memory seats, and adjustable pedals. I will post up the full contents for you... Funny thing is my car is an 05 with cold weather pkg and I don't have a heated windshield... Very interesting...
Just happen to have a 2005 brochure laying around
For 3.0
Premium package:
1) 10 way driver, 8 way front passenger electrically adj. seats with lumbar
2) Power adj pedals
3) Memory driver seat, pedals, exterior door mirrors and steering wheel
4) Electrochromic rearview mirror and exterior door mirror
5) Homelink
6) Rain-sensing wipers
Didn't see a cold weather package but the other options where
Moonroof,
Premium sound,
heated front seats,
Sport package
For the 4.2 optional feature of heated front seats comes with heated windscreen and headlamp power washer in Canada.
For 3.0
Premium package:
2) Power adj pedals
5) Homelink
Moonroof,
Premium sound,
heated front seats,
Sport package
So, I've read so many brochures that it all ran together. Here are the pdf's I was talking about. My car is a base 3.0 with heated seats and moonroof. There isn't a cold weather pkg listed for a US spec car. Nor is there a heated windscreen or headlamp washers...I'd bet a Canadian Spec car made it to the US..
Thanks to all....but....the brochures raise as many questions as the answer.
1. The heated windscreen isn't mentioned at all yet the vehicle clearly started out from Castle Bromwich through Brunswick to Miami. It isn't listed as either a standard nor an optional item.
2. JaguarVoice is listed as not available. However, I was able to add it. Maybe they meant that this only was available as after-market.
Eric
Eric
1. The heated windscreen isn't mentioned at all yet the vehicle clearly stated out from Castle Bromwich through Brunswick to Miami. It isn't listed as either a standard nor an optional item.
Eric
Eric
BTW... All of our year S Types could be fitted with Jaguar Voice as a dealer installed option... Just like the Motorola Phone and Bluetooth..
Now, the S Type did have a second level trim package called "High Line" in North America..That consisted of Burl Walnut wood trim in place of the standard...Plus chrome mirror caps, 16 way drivers seat, 12 way passenger seat, Premium Leather seat trim with pipeing. Plus others...
Here is a picture of a 3.0 with High Line trim..It is an 07.
![](http://images8.ecarlist.com/photos/1962/511910/640/00.jpg)
![](http://images8.ecarlist.com/photos/1962/511910/640/63.jpg)
Actually the difference is this.
A sunroof is a hole in the roof of a car that is covered with a metal panel.
A moonroof is a hole in the roof of a car that is covered with a glass or transparent cover.
Now both of these can be powered or manual. The moonroof can also be fixed or non-movable.
All STR's are pre-wired for Jaguar Voice. So if you have a STR you should be able to plug in the Jaguar Voice module and have it work.
It appears that the S-types are all pre-wired for JaguarVoice. My dealer simply plugged in the module(s). It took about 30 minutes....and about $800. Of course, with the Nav system and the CD changer already there, it may have been easier to do. As I understand it, most of the labor was pulling the Nav/Changer units to get behind then and then putting them back.
What is interesting is that I have the heated windscreen but not the headlight washers!
I hope the pdf gets posted as I haven't tried it before. If the resolution is bad, I'll try something else.
Also, I assume your car has a moonroof, correct? I don't see it listed as an option on the sticker... weird..
I just called the dealer that services my car and asked. It took a call or two to find the right person (service mgr). I expected them to go online and just call it from the file. Instead they got an actual copy. I could stick it on the window if I wanted.
Yes we have a moonroof and it's not mentioned either.
I found a 2005 S-Type brochure that displays the options and specs in a little different format that the copy you have. There are a few "S-Type 3.0 Optional Features"....wheel size, Bluetooth, heated seats, moonroof(!). Then there are 2 "packages"....Premium and Sport. The former has power seats, dimming mirror, power adjustable pedals....a few more. I note that the book calls it the "Premium Package" but the sticker says "Preferred Premium Package" but the latter isn't listed.
Then there are a series of items listed as "Special Order Features". These include Adaptive Cruise Control, Navigation, Front Park Control, Heated Windshield, and Xenon lamps.
It's almost as if they printed the book and built the car without referring one to the other. This can happen as a model spec can be upgraded before new books are printed. However, I'm surprised at the degree of difference.
Considering all the stuff that got thrown in for free....wish they'd included Adaptive Cruise Control.
The 2005 dealer literature I have has several option packages. All packages contain a number of options but the one that stands out when identifying a car is listed.
Premium Package-This is the standard package for the 4.2L and R. Optional only on 6 cylinder cars.
Sport Package-Black on black is only color. Available on 6 and 8 cylinder cars. Not the STR.
Aluminum Package-monotone or dual tone interior. No wood Aluminum surface instead. Available on all cars.
VDP Package-Chrome door mirror caps.
I think the factory literature has some errors in it too? Seen colors and options not mentioned . They don't talk about some stuff like head light washers and if the car has the hood leaper or a flat badge. Of course mine is for North America and they probably only shows what was officially sold.
That dark wood looks nice, but not what I have. From what I've read sounds like I have the Premium Package and my insurance must have listed the VDP wrong. Next time I'm at the dealership I'll have them print everything out in case I decide to sell the car.
As far as not being able to open anything, I read the FAQs and just saw where you had to register. I did that some 6 months ago so IDK. I also remember someone saying you had to post a certain number of times also. *shrug
