Questions about my S type maint. history
Alright here is my car's history. What else needs to be done and what can I expect to go out in the future? Thanks guys
I did not list regular interval maintenance, oil changes, or other minor things. My car has 130k on it.
17 APR 08
Timing chain
Chain tensioner
Chain guide
Chain tensioners
Timing covers seals
Camshaft gaskets
Spark plug seals
Centre seal
Oil filter
Water outlet seal
17 OCT 07
Window regulator
8 AUG 07
Vertical link replaced (LF)
Brake flush
14 DEC 2006
Front muffler pipe replaced
7 DEC 2006
Replaced front and rear rotors and pads
Replaced ball joint (RF)
23 AUG 2006
Power steering flush
8 FEB 2006
Replaced battery
10 OCT 2005
Coolant overflow tank replaced
3 JUN 2005
Replaced headlight master switch
3 MAY 2005
Replaced headlight stalk
4 JAN 2005
Replaced sway bar bushings
Adjusted shifter cable
21 DEC 2004
Replaced transmission
Replaced oil pan and timing cover gaskets
Replaced cam cover gaskets
Replaced ignition coils
3 SEPT 2004
Replaced passenger side rear window regulator
5 JUL 2004
Replaced oil switches
Replaced oil sending unit
27 MAY 2004
Shifter adjusted
11 FEB 2004
Replaced both valve cover gaskets
24 OCT 2003
Replaced drivers side rear window regulator
13 JUN 2002
Replaced thermostat
26 FEB 2001
Replace gas pedal
17 APR 08
Timing chain
Chain tensioner
Chain guide
Chain tensioners
Timing covers seals
Camshaft gaskets
Spark plug seals
Centre seal
Oil filter
Water outlet seal
17 OCT 07
Window regulator
8 AUG 07
Brake flush
14 DEC 2006
7 DEC 2006
23 AUG 2006
8 FEB 2006
Replaced battery
10 OCT 2005
3 JUN 2005
3 MAY 2005
4 JAN 2005
21 DEC 2004
3 SEPT 2004
5 JUL 2004
27 MAY 2004
Shifter adjusted
11 FEB 2004
24 OCT 2003
13 JUN 2002
Replaced thermostat
26 FEB 2001
Replace gas pedal
RE: Questions about my S type maint. history
ORIGINAL: badmojo
They forgot to replace the body! LOL. Man that's a lot of work. Did you buy it new?
Cajun
stanjag
08-30-2015 10:35 AM
Terrance Williams
08-26-2015 11:50 AM
