Radiator possibly leaking?
I walked outside today and noticed some coolant on the ground, passenger side just below the heater valve. I took the bottom plastic off of the car to get a closer look and followed the trail up to the top of the radiator where I see green coolant in 1 of the seams. its about 2 seams on the outer part of the radiator right next to where the foam runs down to the bottom of the radiator. Not sure if there is a crack there, but its very hard to tell. I did wipe it, started the car and then saw it start to fill back up again. I do not see the coolant in the reservoir drop much at all. I replaced a few radiator hoses a couple months ago and went to the Jaguar dealer and had a flush done to the system. They tested it for leaks and did not find anything. Any ideas? Also, common for the radiator to leak or no? Thank You
I've no notion what MY/eng you have, or if it matters. Our 2003 3.0L V6 S-Type sprung a leak from a crack in the radiator side-tank, RHS, IIRC back in Dec, 2012. So yeah, they can leak. I changed the DCCV pre-emptively while I was in there, and the new one started leaking a few days later, put the orig, non-leaking one back on which served well for about two weeks, at which time I swapped it out for the replacement part rec'd after turning the failed new one in. So far, good since then.
just had the pressure test done to the coolant system, and yes the radiator is leaking. There is a small crack on the passenger side of the radiator, right next to the upper coolant hose. So here is the breakdown...
Tires plus gave me a quote of $669 for the radiator, which includes parts, labor, antifreeze, flush, tax etc. I was also told it has a LIFETIME WARRANTY on it as well. I do have the write out in hand. They said it would be a aftermarket direct fit radiator. The guy went on and on about saying that Jaguar has a radiator made for them, that JAGUAR does not produce radiators.
Now, the best price I have seen for a BRAND NEW OEM radiator is through Welsh Jaguar for $295+ shipping. Labor I am guessing is a couple hours about 2 hours maybe? Plus the cost of coolant.... I would be looking around the same price.
Would I be better off buying a OEM from Welsh and taking it to my local Jag guy to do the work, or is it better to get a aftermarket with a Lifetime warranty? I would rather go with OEM over aftermarket especially in Jaguars.
What advice can you guys give me? Are aftermarket radiators any good? Thanks for anyone's input on this
rusty37
04-05-2020 07:40 PM
