Radiator replacement, Jag brand required?
At 91k miles, my daily driven 2004 S-Type (V6, base) has developed a slow coolant leak from the radiator and, therefore, needs a replacement.
The radiator Jaguar quoted my local shop is $580. The radiator that fits my model on JagBits is about the same.
Nearly $600.00 seems a bit steep for a radiator, when Summit Racing have two that will apparently fit a 2004 S-Type, a Lincoln and a Ford of some type (leading me to believe the radiator is a Ford part), the most expensive of which is $117.00.
https://www.summitracing.com/search/...rder=Ascending
Is there a compelling reason to choose the Jaguar radiator at nearly five times the price? Does it feature better construction, more efficient engineering or a better warranty? The shop owner is a friend and he’ll happily sub out the part if I can get one that’s just as good for less money. While I want to save a few dollars, I don’t want to do so, only to incur a bigger expense later, by buying the wrong part.
Thoughts?
Thanks in advance,
Rhett
Thoughts?
Thanks in advance,
Rhett
if you have the automatic gearbox, as I suspect you do, then you'll need a radiator with the integral gearbox cooler. The $100 radiators generally do not, and fit the S-Type manual cars. I don't know the true figures, but suspect USA sales were 90%+ autobox vs. manual, while a search for replacement radiators would indicate the exact opposite.
Do a thorough search of this forum; seems there was a post or two within the last couple years where some chaps had linked to an affordable radiator with the integral gearbox cooler.
The following 2 users liked this post by aholbro1:
motorcarman (07-01-2019),
Rhett (06-30-2019)
The following 2 users liked this post by motorcarman:
davidladewig (07-10-2019),
Rhett (07-04-2019)
I bought the same one for my 06 str last year..very well made...fits perfectly....also fits op car as Bob said. ..new materials and construction over oem I think . .highly recommend
Received 2,652 Likes
Man on the hill
07-15-2017 08:17 PM
the-jag-guy
03-07-2013 09:53 PM
The_Sauce
05-19-2010 11:33 AM
