Radio Security Code upon Battery Replacement
My OE battery that originally came with the car must be a good bit beyond its 5th birthday, so I'm trying to anticipate what's involved with a new battery. In the Owner's Handbook (page 196), there is a list of 7 things to do after reconnecting the battery.
One of the to-do's called out is to re-enter the radio security code. I'm not sure that I have that code amongst my listing of a few mystery codes. Could anyone give me a clue as to the format of the radio security code (how many digits, any alphas, etc.)?
I did do a search of the Forum with not much success except for a couple of postings that said the radio security code was not needed after reconnecting the battery - so the Owner's Manual is wrong?
Also, any experience with the two type of battery technologies available? The AGM (absorbed glass mat) sound like they do not need to use the in-boot battery vent system, while the "conventional" wet batteries still do. The AGM type are a bit more expensive. Any feed back?
Thanks (especially for the format of that radio security code)!
Received 6,330 Likes
My battery code was 4 digits long. I wasn't sure what it was so I called into 1800-4-Jaguar (Jaguar's 1800 number) and asked one of the customer service agents if they can provide me with the radio code. They did require proof that I was the owner (a copy of the current registration and a photo id) and it was very simple and quick process.
For the battery, I would just go to one of those local auto parts stores and get what they have available. I got mine from Advance Auto Parts. They installed it for free and the battery has a pretty good warranty (3 year replacement and up to 8 year pro-rated). I used one of their online coupons and it was like only $98 at the end.
By the way, after I got my battery replaced, the radio didn't ask for a code. I think there might be a certain "grace period" (if that would be the right term) the radio has before it requires the code to be unlocked. Wonder if anyone else was in my same boat.
SCMike (06-24-2012)
Save any of the messing around by connecting 12 volts to leads before disconnecting from the battery.
Park another car next to you, lug a battery, or make up a pair of long wires. Just speaker wire or similar is OK, as there is no current to speak of unless you try starting the vehicle! These can become a handy part of your tool kit.
Shops here use a small 12v motorcycle battery with crocodile clips.
If you're in Mississippi use alligator clips.![Icon Duck](https://www.jaguarforums.com/forum/images/smilies/icon_duck.gif)
Cheers Jeff
Cheers Jeff
George Smith (09-30-2022)
I remember wondering the same thing when I was first contemplating a battery change.
I've had to disconnect my battery so many times now I think I have second career as a battery jockey in waiting at Pep Boys. OH Joy!
You won't need a code.
You're ECU will be stupid & ignorant again. Enjoy that while it lasts.
The damn things are like parrots and pickup every bad driving tendency.
bfsgross (06-25-2012)
The message ENTER CODE shows you do have a code locked radio.
Try pressing [A.Mem + PTY + >>] at the same time as suggested by Jeff in #3 above to bypass this.
If this doesn't work, you will need the four digit code. In vehicles requiring a code this is originally on two (credit card sized) cards and looks like this:
![Radio Security Code upon Battery Replacement-radio-security-code-card-.jpg](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/21003d1480966675t-radio-security-code-upon-battery-replacement-radio-security-code-card-.jpg)
As you don't have the code cards, options are:
1. check for the number written on the radio unit itself
2. contact any Jaguar Dealer (with proof of ownership)
3. use one of the services listed on eBay that claims to be able to get the security code from the radio serial number
As there is no connection between the radio serial number of my radio and the security code, I do wonder just how the eBay listers claim to be able to do this.
edobernig (07-06-2012)
Staatsof, I think you owe the OP and the other stupid ignorant people whose experience happens to be different to yours, an apology for shouting the "obvious" in agreement with bfsgross. (bfsgross, no offence to you, your comment was not presented offensively)
For what?
I stated what I experienced in my car.
So I should apologize?
Please explain.
I don't beleive I was offensive to anyone, well maybe the programming of the ECU.
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Welcome to the forum Luis,
Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post an introduction about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice on posting to the forum.
hello,
i have the same problem afhter replaced battery. If i press EJECT+PTY - as suggested on web) i see a code as: 000 xxxxx But this seems not to be the code ( also they are are 5 digits and not 4) Someone can help? I am from sicily.. Jaguar dealer is about 100km away from me and he ask €25 to get the code.
thanks
thanks
hello,
thanks
thanks
The radio security code on a European specification Jaguar is a four number sequence. I've read many suggestions over the years for combinations of buttons which are supposed to bypass the security code but have never found one that works.
There are varied reports about OnLine radio code providers. Some have worked but most have failed. They all charge so it's safer to pay the dealer for the right code.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Thank you Graham.
Welcome to the forum freemenn,
