random misfire only when it's cold
hallo everyone.
I m just new in the forum.
I want to share with you the issue of my jaguar s type 3000 v6 petrol year 2003
only when the engine is cold , for istance first start of the day, the engine has a random misfire.
than become normal around 60 deg.
of course i have already changed the spark plug also the M.A.F. is new
anyone can give me me an input?
thx a lot in Advance
The following 2 users liked this post by neilr:
kr98664 (02-15-2021),
S-Type Owner (02-15-2021)
after about 3 min. and about 60 deg. everything works well. i clear the code and for all day is perfect even if i park the car for 5/8h. it s related with cold wheter operation, in the summer it do the same in the morning but less less less.
See page 29 here for code P0300:
http://www.jagrepair.com/images/Auto..._OBD_II_R2.pdf
The column at the far right has a list of possible causes. Since you are not getting a code specific to one cylinder, I'd suggest first checking fuel pressure, as that would affect all cylinders if out of specifications.
JagRepair.com - Jaguar Repair Information Resource
Maybe you've got a leak not bad enough to set other codes, but just enough to cause rough running when the engine is cold.
On a related note, these are not the exact symptoms you are experiencing, but check the resonator as seen in this thread:
https://www.jaguarforums.com/forum/s...solved-198690/
Dirkman
08-30-2012 06:53 PM
