RCCM repair guy??
My RCCM needs the "fix" due to faulty DCCV
Where is the best place/person to send it to?
I emailed - JaguarClimateControl.com but have not received a response.
Received 6,320 Likes
Extremely straight forward repair. Even a novice armed with a soldering iron and a multimeter would be able to tackle this one.
However, if you're uncomfortable doing it, I am certain a local electronics repair shop would be capable of performing the repair. Check your local yellow pages for electronics repair shops.
Take your CCM apart, remove the damaged circuit board from the CCM following the instructions found at jaguarclimatecontrol.com website.
You should be able to identify the burnt circuits on the board with the naked eye.
Bring it to the electronics shop, point out specifically where the traces are burnt, there should be two burnt circuits, and it shouldn't cost you more than $20-$100.
