Really need some help removing wiper motor and linkage from 2000 Stype 4.0
The wiper motor is faulty in my 2000 Stype, left hand drive. So far I have the following done: (I've searched this site, also have an online manual through alldata, and just googling as much as I can)
Removed:
- wipers
- plastic cowl
- bolts for coolant reservoir, I can't fully remove this tank because the bottom hose I simply can't get to the clamp to release it, even through the wheel well
- brake pedal retaining clip/pin behind the brake pedal arm
- brake booster 4 nuts inside drive footwell up behind the brake pedal.
If I could just shimmy the brake booster forward just a bit, I think it'll all clear but the booster is not budging forward. I can lift the coolant tank up and out of the way even with the main bottom coolant hose connected. There's space ahead of the booster to move, not much but it should still shimmy ahead .5 - 1 inch but isn't budging as if there's something else holding it.
I run windows 10 64bit and I know the last time I tried to get the jtis stuff to work, I couldn't. Unless there's a searchable pdf version?
Removed:
- wipers
- plastic cowl
Can anyone help me locate the brake booster retaining nut? Maybe if someone sees this they might know enough to get me over the hump!
In the manual, I'm struggling to find where these diagrams are pointing on pages 560 and 561. Image VUJ0005552 on 560 and E30380 on 561...I'm thinking it's in the driver foot well somewhere above the pedal assembly? Even then I'm not having much luck locating it, I think this is all that is holding it.
Thanks!
Thanks!
Robert Laughton
10-07-2019 05:55 PM
bill dobbs
05-02-2015 09:55 AM
