Rear ball joint boots
I noticed that the rear ball joint boots are split. Still grease in there and surely not worn out at 20 thou. Certainly not worth buying new control arms.![Icon No](https://www.jaguarforums.com/forum/images/smilies/icon_no.gif)
So I did a quick search and came up with this.
Ball Joint Boot - Auto Parts Warehouse
Perhaps an alternative if I could get the sizeing correct?
The Energy Suspension site has them listed by dimensions. If someone had a set off to measure it would be great. I figure anything would be better that the split open ones.
This site has what seems to be all the dimensions available
http://www.suspension.com/bjb.htm
Suspension Restoration Parts Co. - Polyurethane ball joint boots and tie-rod boots.
I will measure them this weekend and order the approriate ones, I plan to take the vehicle to the shop and replace the rear tie rods and links. might as well do this at that time.
Thanks, I have a set of front uppers already taken off, I think the BJ's should be the same size as the rear.
Please post back what you find. Part #s would be awesome. This would be a huge savings if it could work.
Will do.
On a related note, this is the first time I see a seller offering the front upper control arm bushings. Along with the boots, this can save some of us $$ by avoiding having to purchase a brand new arm:
JAGUAR FRONT UPPER WISHBONE CONTROL ARM BUSH BUSHING | eBay
Does anyone know if the upper front control arm bushings and rear upper bushings are interchangable?
Ok, I was able to take the measurements, just had to clean up the front arm and take the boot off.
View from top:
![Name: IMG_0897.jpg
Size: 50.4 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/170501d1501284444-rear-ball-joint-boots-img_0897.jpg)
Diameter Base of Ball Joint Measured 1 3/8":
![Name: IMG_9201.jpg
Size: 44.0 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/170502d1501284444-rear-ball-joint-boots-img_9201.jpg)
There was a metal ring on this groove securing the boot. Diameter was 1.220 almost 1 1/4":
![Name: IMG_3200.jpg
Size: 46.8 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/170503d1501284444-rear-ball-joint-boots-img_3200.jpg)
There is another metal ring securing the boot inside. Diameter was 5/8":
![Name: IMG_5670.jpg
Size: 45.5 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/170504d1501284444-rear-ball-joint-boots-img_5670.jpg)
The diameter of this following piece was 1 1/16" :
![Name: IMG_0845.jpg
Size: 40.6 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/170505d1501284444-rear-ball-joint-boots-img_0845.jpg)
Finally, the height from the base to the underside of the threads was 7/8"
View from top:
![Name: IMG_7822.jpg
Size: 39.3 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/170506d1501284444-rear-ball-joint-boots-img_7822.jpg)
Richard_gib
09-12-2015 07:08 PM
