rear brake caliper piston just spins/need correct tool
Guest
Posts: n/a
Im new here. I have searched and searched with no luck on my exact problem and I also need a few tips im sure. Anyways here is my problem. Im changing the brake pads and rotors on a customer's car, its a 2000 s type v6. The fronts went with no problem. The rear on the other hand is giving me a big problem. I can't seem to get the piston to go all of the way in. On the passenger side I got it to screw in a good amount but now it just spins and doesnt go in any farther. On the driver's side iv pretty much givin up because my tool keeps slipping out of the grooves. I could use a link to the correct tool because right now im using one of those cubes and on the side that has 4 nipples i grinded 2 of them off but it still slips off like crazy. Do i need to remove the parking brake line? Any other tips? Thanks.
Welcome aboard, SlowChevy.
This looks familiar: (Post #12 has a link to one tool that works.)
https://www.jaguarforums.com/forum/s...lp-fast-52107/
Not necessary to remove the park-brake cable.
I have a 2000 S-Type and this link should help http://www.gusglikas.com/images/Auto...RearBrakes.pdf
Great post, thanks. I have a problem with my 2008 S-Type 3.0.
The tool you picture and the tool kit that Auto Zone lends does not work with my rear pistons. The spacing of the hole/indentation on the piston is closer than any of the tool options. Therefore I can not rotate the piston. Also the pads have pins/projections that should position the pads correctly to the pistons. This does not happen as the spacing on the pads is different from the pistons. What happens is that one pin seats properly but the other can not align so the pad ends up cocked. I only have 23,000 miles on the 2008 S-Type but the pads are completely gone and the disks are worn away 1/16 of an inch. I bought new calipers, disks and pads from Auto Zone and they have the same problem. Pin center to center distance is different from the piston holes center to center distance.
I talked to Auto Zone and they are baffled so I am heading to the dealer with the caliper in hand and buy pads with matching pin centers if they have them. Perhaps I will also need to purchase new calipers.
Anyone with a similar problem?
Received 2,263 Likes
Received 6,315 Likes
I would check you have the correct pads, for your Vin No# > N52048?? Dia 326mm back disks.
I removed odd/strange rear pads from my 4.2 which someone had managed to force in, which had backing location springs on the back of the pad, making the pad and disk clearance far too small.
This caused extreme screeching once the brake dust built up.
The correctly fitted pads, cured this.
The old pads looked the same physically but had these springs on the back of them?
May be someone fitted the incorrect pads to your car in the past. 1/16" sounds a lot for 24k.
I also tried a couple of wind-back tools, without success to turn the piston back, got it with long nosed pliers thou.
Have a look at at some of the on line vendor cats for pad details and sizes.
But check using you car vin no#
philwarner
09-05-2015 10:05 AM
