Rear control arm bushings
Hey whatz up every one. I just found out that my need some suspension work. I know that for the most part and I ordered up some new sway bar bushing and links front and rear. I was planning on doing also new shocks an H&R springs but, that looks like it going to have wait. I found out that my lower rear control arm bushings are shot and need to be changed out and rear stabilizing links. I found out that the bushing on the lower control arm can be change out instead of buy a whole new control arm for $800 buck a pop. I found this out on
http://www.jaguarforum.co.uk/viewtopic.php?f=16&t=34593
They are from racing green cars ltd. They have made some replacement bushing that you can press in.
http://www.thejaguarshop.com/Jaguar/...wards/b%7C.htm
I am going to be ordering up some soon. I was wondering if anyone has done this before?
Just leave the bushings alone. Does the suspension have any kind of noise in the front or rear, any kind of play??? If not then I would leave them alone altogether. The control arm bushings being crack never cause any issues that I have seen, The front links and sway bar bushings on the front can make clunking noises, but the rears I have never seen those make noise. Unless you have excessive play or a noise, I would leave them alone.
