Rear Disk Brake Advice
I'm replacing rear pads and rotors on my 2005 S Type 3.0. I didn't have any issue removing the caliper and it's frame, but I'm not able to get the old rotor off. AllData says there are retaining clips on a couple of the studs but I'm not seeing them. The rotor won't budge.
What do you recommend I do to get the rotor off?
Thanks for your help,
John
John
Jumpin' Jag Flash (01-04-2016)
Deal with this a lot. I agree with Motorcarman, penetrating oil and mallet, but also try using a butane torch to warm the center of the disc around the hub. I've had good luck with that. Be careful if using a hammer, I've watched slobs smash the lead threads of their wheel studs, ruining them, and making a lot more trouble for themselves.
Received 2,263 Likes
You're looking for the classic S-type section. This is the modern 1999-2008 S-type area.
S-type 2000
12-16-2015 06:53 AM
