Rear Electronic Module
Old 11-19-2011 | 05:51 PM
Torrid's Avatar
Default Rear Electronic Module
I've determined that the rear Electronic Module is bad on my 2000 S-type 4.0. If I buy a used module does it need to be programmed to the car or is it plug and play? Thanks.
Old 11-19-2011 | 06:07 PM
Gus's Avatar
Gus
Not sure if it needs to be programmed to the car but what makes you think you need a new electronic module?
Old 11-19-2011 | 07:51 PM
Torrid's Avatar
My reverse lights and high center mount brake light do not work even though the module is receiving the signal. I tried wiring relays to fix the lights, but the signal wires going into the module stop sending out power when the relay is used because even the relay is too much current draw.
Old 11-19-2011 | 09:06 PM
Gus's Avatar
Gus
Did you check your grounds?
Old 11-20-2011 | 01:02 AM
Torrid's Avatar
Yep. I even powered up the circuits and had power at the output of the plug, but the module will not switch and everything is solid.
Old 11-20-2011 | 09:29 AM
motorcarman's Avatar
If you get a used RECM you probably need to have the matching suffix from the VCATS or it might not operate properly (if at all).
There are 2 different modules for the X200
Up to VIN L68491
From VIN L68492 to M45254
(USE THE PORTABLE DIAGNOSTIC UNIT TO DETERMINE PART NUMBER SUFFIX)
or use the VCATS LABEL from the car
BOTH NEED TO MATCH!!
I don't remember if they need to be configured to the other modules on the SCP network.
bob gauff
AD2014 (04-01-2018)
Old 11-20-2011 | 10:51 AM
Torrid's Avatar
Thanks guys. I would take it to the dealer and have them install a brand new module, but I know the cost would be catastrophic and I am a do it yourself kind of guy. I'd love there to be a simple programming process. I changed the BCM on my 2004 GTO and all I had to do was follow a set of key on and off sequences in 10 minute increments for 40 minutes following horn honks.
All I can say is trying to back up a car in a crowded parking lot is near impossible without working reverse lights.
Old 03-31-2018 | 07:45 PM
SteveLeighton's Avatar
Could someone please let me know how to find the REM? Thanks
Old 04-01-2018 | 09:25 PM
The Jaguar Electrical Guide will have all the module locations and pinout ID in the FRONT MATTERS section.
bob
Dagny
06-11-2024 02:06 PM
H20boy
07-23-2021 10:39 PM
kevinl
10-31-2019 07:15 PM
joey g
US Northeast
09-07-2015 07:28 PM
laserguy
09-03-2015 03:02 PM
Quick Reply: Rear Electronic Module
