Rear main Fuse issue
Alright question for my big wigs. Due to all the random issues from car i decided to do some poking around. In my poking i took the trunk right wheel well cover off in the trunk and started checking wires from rear fuse to battery to harness. This is what i discovered. So the top right terminal metal bar that crosses over to lower terminal coming from batter and trunk fuse box connected is loose and fried. Not bolt loose but like broken and free where it meets the 250A fuse. melted the plastic and a little of the cable and is all corroded. Out of curiosity i ran the car walked back there wiggled it around and nothing happened. But i did get quite a burn as it gets very hot which explains the plastic. Could it be getting hot because it’s broken? I’d say not because it must of blew or malfunctioned causing it to get hot now. Is it supposed to be a 400A dude like the one above it? Has anyone EVER seen this on this car or others? I’m leaving the plastic off due to how how it gets but any ideas on why this is happening ? I will try to source a new fuse but what could cause this. Thanks guys.
Received 2,677 Likes
The whole junction block must be replaced after the draw is found.
Here is a link to the MY2003 Electrical Guide:
https://www.dropbox.com/s/1ocfmq0ivw...Guide.pdf?dl=0
Many of the main circuits are the same after the facelift.
James Finney (03-11-2020)
Here is the post facelift Electrical Guide, which is the correct one for your vehicle:
https://www.dropbox.com/s/x3ksf8ird8...006on.pdf?dl=0
Or if you do not want to use dropbox here is a direct link to a pdf:
http://www.jagrepair.com/images/Auto...cal-2006on.pdf
Mellow
Mellow
If you look closely at that cable terminal end, can you tell which end got hotter? Does it appear the heat originated at the crimp and moved towards the fuse block? Or does the fuse end appear hotter, and the heat transferred toward the crimp? If the fuse end was the source of the heat, that was probably not caused by the fuse itself, but the bolted connection. From the little bit I can see, it looks like the heat originated at the crimp.
Don't drive the car like this. That is totally abnormal to see such heat damage. It will continue to get worse. That cable feeds the front power distribution box. The biggest fuse there is 50A, but most are in the 20A range. If the draw was caused by a fault downstream of the front power distribution box, even the biggest fuse there would have opened first, long before any damage would occur back by the megafuse. It wouldn't hurt to inspect the front power distribution box for any signs of heat damage, just to be safe.
As previously mentioned, you'll have to replace that entire fuse block assembly. You'll have to splice in a new section of cable, too.
Looking at your pics, it would appear that cable crimp has failed. A loose or corroded crimp has extra resistance, which heats up due to normal current flow.
No idea about differences between models for the megafuse block. I would think they're all the same for a given year. Match the existing fuse rating.
NBCat (03-12-2020)
Looking at your pics some more, it appears you've got two megafuse holders side by side. I had initially thought it was one big unit, but it's more of a modular design. Take a look at this, from Littelfuse:
https://www.littelfuse.com/products/...981001zxt.aspx
If that is correct, these megafuse holders are readily available from many sources. You don't have to buy the expensive Jaguar version. Here's one example on eBay, complete with a 250A fuse. Seller says he ships worldwide, not sure where you are located:
https://www.ebay.com/itm/LITTLEFUSE-....c100005.m1851
Got to thinking a bit more about possible causes of the overheat. Perhaps the heavy cable between the megafuse and the front power distribution box is lightly contacting ground, creating a not-quite-direct short circuit. Had it been a direct short, amperage would have exceeded 250 and that megafuse should have blown. Maybe it was only 249, or just enough to find the weakest spot in the cable run. If so, here's what I suggest. As previously mentioned, replace the megafuse and holder, and splice in a new section of cable. When you first connect the battery, don't tighten the clamp right away. Observe if you get a big spark as you make contact. It's normal to get a light spark, but not a heavy one. If that happens, quickly disconnect the battery cable and investigate further.
UPDATE
One question. Could this fuse cause any ignition coil, plug, injector, or sky misfires what so ever? or would that be power to engine fuse compartment. They do trace one way or another just wondering if it could be possible.
Okay so i have done everything. I replaced the 250 amp fuse and the plastic block encasing it. Got a new crimp to cable spliced the original cable past the point of corrosion and crimped it together. I didn’t not replace the block reason being i pulled it checked all connections all voltage with meter traced with electrical guide and everything checked out even fuses. The mega fuse was completely blown in half the terminal pulled right out of it. I reconnected slowly and lightly and got no spark what so ever as i had battery unplugged as should be. When connected normal relay clicked and everything was fine. I went to ignition turned the key to second position before start everything came on nicely. Ran to the back and touched my new connections. NO HEAT. Started car let run. NO HEAT. Before i was idling at 5/600. had misfires abs codes gear box codes dcs codes the whole 9. They are gone as for right now and the car idles 800 healthy!!! All gas seemed like to check out. Thank you all again.
Could this fuse cause any ignition coil, plug, injector, or ... misfires what so ever? or would that be power to engine fuse compartment. They do trace one way or another just wondering if it could be possible.
However, keep in mind the computer is back in relearning mode because you had the battery disconnected. Several drive cycles may be required before certain faults reappear. Continue monitoring it and see what happens.
The following 4 users liked this post by kr98664:
Also i constantly drive with a scanner hooked up to get all my trims and i had an overheating problem before it was mainly to monitor temps because i know better than to trust the gauge. There’s no in between. it’s either just right or dangerous lol. So my trim status should be closed? The scanner is the Scan Gauge 2.
also i know you’re going to say something about the compression. My buddy has an 04 str and it’s the same. Is that normal or okay for a 9:1? So far i’ve seen 120 being the normal even with wet testing. What are yours ? I only mention this because the factory page don’t remember which one says this car should have a 160 or higher compression which i find hard to believe ..
