Rear Parking sensor problem on S type
Old 03-31-2013, 06:41 PM
winjenkins's Avatar
Question Rear Parking sensor problem on S type
Hi - I am a new (but old) member and this is my 1st post. I have had my S type 3 litre Jag (manufactured in 2003) for 3 years and suddenly the rear parking sensor alarm has come on and stays on when I go into reverse. The outside of the sensors look clean. Is this likely to be a faulty sensor or a faulty control module and can I check which it is. Also can I disable the alarm in the meantime as it is driving me nuts when reversing.
Old 03-31-2013, 06:48 PM
Received 9,011 Likes on 4,114 Posts
Hey there I'm sure the S typers will be happy to help
Old 03-31-2013, 08:34 PM
bfsgross's Avatar
Default Faulty sensor
One of the sensors went kaput. Go into the trunk and on the rear left wall of the trunk are two modules. Till U replace the faulty sensor unplug the module on the right.
The following 2 users liked this post by bfsgross:
kevo (03-29-2015), winjenkins (04-02-2013)
Old 04-01-2013, 02:37 AM
JagV8's Avatar
Received 4,538 Likes on 3,947 Posts
Or it could be the module.
You can check existing threads for how to test and other checks such as for water.
Old 04-02-2013, 12:51 PM
winjenkins's Avatar
Question
Many thanks bfsgross I have found a module above the cd changer which I assume is the for the sensors. Will it make sense if I unplug the sensors one at a time to see if the audible alarm goes off?
Old 04-02-2013, 01:02 PM
winjenkins's Avatar
Contrary to my earlier response I am now not sure that the module above the cd changer is in fact the distance sensor module. Is it behind the plastic cover at the rear of the boot?
Old 04-02-2013, 01:47 PM
JagV8's Avatar
Mine's near the trunk lock and says on it
...-15K866-...
Old 04-02-2013, 06:35 PM
bfsgross's Avatar
jagv8, correctly describes the place and module. look on the left side of trunk on wall that also holds the rear bumper cover (rear bumper side of spare tire).
Old 04-03-2013, 09:00 AM
winjenkins's Avatar
Thanks jagv8 and bfsgross - do I have to take rear bumper cover or boot lining off to see module?
Old 04-03-2013, 09:36 AM
bfsgross's Avatar
LOL, no. Just open the trunk and peer down to the left on the wall of the trunk that holds the bumper cover and rear tail lamps.
kevo (03-29-2015), winjenkins (04-03-2013)
Old 04-03-2013, 09:51 AM
Received 6,330 Likes on 5,516 Posts
Mine is on the left hand wall of the spare tyre well.
File Type: pdf
The following 3 users liked this post by Norri:
bfsgross (04-03-2013), Jumpin' Jag Flash (04-09-2013), winjenkins (04-03-2013)
Old 04-05-2013, 06:09 AM
winjenkins's Avatar
Nothing in the spare tyre well apart from battery and main fuse box nor on the wall that holds the bumper cover, so can only assume the module I mentioned in my first post (in the cupboard that holds the cd changer) is the one for the distance sensor. Unfortunately I will have to remove the boot lining to get at it. I will have a look Sunday morning.
Old 04-05-2013, 06:32 AM
JagV8's Avatar
I'm very doubtful the module is located elsewhere if it's the OE one.
Old 04-07-2013, 08:29 AM
winjenkins's Avatar
Thanks JV8.
Have again looked in boot and spare wheel well but no sign of it.
Have attached photo of boot & well and also photos of right and left side of boot behind lining. Does anything in there look the module?
Attached Thumbnails Rear Parking sensor problem on S type-boot.jpg   Rear Parking sensor problem on S type-left-side-boot.jpg   Rear Parking sensor problem on S type-right-side-boot.jpg
Old 04-07-2013, 09:23 AM
JagV8's Avatar
No, but I posted the number to look for.
Maybe an aftermarket non-jag fit.
winjenkins (04-08-2013)
Old 04-07-2013, 11:17 AM
clubairth1's Avatar
Received 2,427 Likes on 1,907 Posts
I don't know why but there is no module where it should be? It should be on the left hand wall of the spare tire well.
See you picture labeled below.
See that white plug tied up by the red arrow? That plugs into the module.
What's taped and wrapped up on the back wall by the lug wrench? Does not look stock??
Old 04-08-2013, 12:37 AM
sprdav33's Avatar
Definitely missing the module. The wrapped up wires are probably for the CATS. I have the same foam and tape on my car that has regular shocks.
Old 04-08-2013, 09:26 AM
winjenkins's Avatar
I have come to the conclusion that the parking sensor system is an afterfit but have not yet found where the module is situated. I think it is probably behind the lining on the rear LHS of the boot with its own speaker located under the back ledge behind rear seats (there are a couple of wires going up there from LHS of boot wall).
Have listened to sensors on bumper and cannot hear sound from the one on near side. Problem is if it is in an afterfit system it may is not a Jaguar part. So what do I relace it with - that is the $90 question.
I might have to resort to disconnecting the speaker and doing without the sensors.
Would appreciate any advice.
Old 04-08-2013, 03:59 PM
GoKittyGo's Avatar
I was having the same issue, my son found the wire bundle(?) and tightened the connections and it works properly now.
winjenkins (04-10-2013)
Old 04-09-2013, 07:45 AM
Jumpin' Jag Flash's Avatar
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
If you can find the fuse for it, try pulling it instead of disconnecting speakers. That way you'll actually shut the damned thing off so it doesn't continue to draw power as it might if you've only disconnected the speaker.
Quick Reply: Rear Parking sensor problem on S type
