Rear parking sensors
I seem to have an issue with my parking sensors. The sensors will not beep, and the light inside of the button in the overhead console stays lit, even when pressed.
I've listened to all four sensors, there is a rapid clicking sound coming from all four sensors. Does that rule out faulty sensors or a faulty module?
I do have a one reverse light out (Passenger side US), could that be the culprit? I'm not sure when exactly I noticed the sensors weren't working or if it even corresponds with the reverse light.
I've had same issue with parking aid/button light staying on. Do you have a DTC scanner? When I scanned, I found DTC indicating one parking sensor in rear bumper to be bad. It may be same issue you have. Maybe one or more. I believe the corner sensors can be accessed by removing tail lamp assemblies, but inboard ones are hard to get to. Maybe removal of bumper is easiest way to check all sensors? Or is there a better way to do it?
The bulb failure won't affect park aid sensor operation. The park aid module just receives a signal saying the vehicle has been put into reverse.
Usually - if a sensor is faulty, you will get a solid tone from speaker. If there is no tone at all, a possibility is the sounder/speaker is faulty. Another possibility is the module, possible water ingress as this has been a common issue due to where the module sites, next to spare wheel.
You can disconnect the connector and see if there is any corrosion noticed on the pins or the pins in the module itself.
