Rear passenger door problem
You'll probably need to remove the interior door panel and have a good look at your door latch mechanism in order to determine what may be causing the problem. It could be anything from misalignment to broken components. I believe that Rick (joycesjag) had to replace some rear door latch parts recently on his 2005 S-Type. If he's around today, I'm sure he'll chime in here with more details. You may also want to search the forum using the key words "door latch repair" or something similar....
You may want to try lifting the exterior door handle and spraying some lube into the upper recess of the door handle. You may have to do it a couple of times.
You can refer to the link for what you are going to be dealing with.
Have fun!!!
https://www.jaguarforums.com/forum/s...ics-faq-65657/
Have fun!!!
BrentGardner
28
04-26-2024 03:08 AM
hafren
08-30-2023 03:42 PM
