Rear RH indicator/reversing light fault
I've got a fault with the RH rear indicator. When the RH indicator is turned on, the rear bulb doesn't illuminate fully (like a dim glow), and the RH and LH reversing lights also glow dimly. It looks like there is a short between the reversing lights and the RH rear indicator bulb somewhere.
There's no problem with the LH indicator.
Also the RH reversing light doesn't work. I suspect this is connected with the same fault.
I've got a multimeter and the JTIS CD.
Any idea where to start? Is this a common fault?
99xk8guy
06-05-2023 06:28 AM
innzane
09-02-2015 10:08 AM
