Rear Stab-bar bushing replacement
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Given the awful estimates of time & money to replace the rear stabilizer bushings (I have large hands and would not be able to manipulate the change process), has anyone considered a more top down approach?
I don't know if it would be practical, but could one cut suitable holes through the trunk - enough to change the bushings, then reseal the holes?
Any idea where to cut?
Obviously the goal would be to do this as esthetically as possible (for resale purposes), but it seems it has to be easier than the 6.5 hours and megabucks to lower the whole rear end!!
Any comments (other than you must be mad of course)?
Mine is a 2003 S-type 4.2 base
JTIS procedure is to drop the subframe.
Is there a reason for wanting to replace the bushings?
There was a thread somewhere on the estimate given someone by a dealer to do this job and it was BIG. I don't know for sure if they do need doing, I will get my camera on a stick and evaluate more.
I have already done rear tie rods and stab bar links but am still getting thumps from the rear. These thumps are worse when both wheels go over the same crack/bump simultaneously. One wheel at a time gives less bump. This seems to point to sway bar issues.
Thanks however for the structural info, I guess I'll have to save up for an expensive Canadian Dealer job! (if they need doing)
Fraser Mitchell
10-01-2015 04:06 AM
Doug Dooren
08-30-2015 08:51 AM
