rear suspension parts
About a month ago, my car went from quiet to a very loud annoying squeak. It squeaks just from me sitting down in the car. There was a thread I found talking about the rear suspension and bushings being the primary culprit (can't find the thread now). It finally stopped snowing long enough for me to take a look, plus I had to put on my new gorilla lugnuts anyway.
I took pics of the ones that looked bad:
https://i.imgur.com/puPiMbA.jpg
https://i.imgur.com/982wcB7.jpg
https://i.imgur.com/5P6jhDn.jpg
Can I replace just the bushings on these parts? Or, for instance, would I just buy a whole new tierod?
The UK forum has a great and very though thread on suspension bushings.
Read the entire thing as people keep adding to it and more parts are becoming available from the aftermarket.
The definitive wishbone bush thread
But lets do the easy things first before buying parts. A very common sqeak point is the sway bar bushings and they are simple to check. Unbolt the sway bar end links. Do the front first as they cause the most problems. Then drive around or bounce the car to check for your noise . Then unbolt the rear sway bar end links and do the same thing.
innzane
09-02-2015 10:08 AM
