the rear sway bar mounts
So guys the rear sway bar mounts are a disaster to replace there is hardly room but it's manageable....so my question is are the original ones made in 2 halves?
I have the febi ones but they are a really a pain in the **** to get them in the sway bar nearly impossible....or did you guys mounted the power flex/ steongflex ones?
I used Powerflex bushes. There are NOT two parts per bush. I dropped the subframe when I did mine. Use rubber grease to aid assembly. Make sure you have the correct size bushes (IIRC there is a different size option, depending on which model you have). Don’t lose the retaining brackets, like I did🙄.
al_roethlisberger
05-25-2017 07:05 PM
weisberg
07-20-2014 11:34 AM
