Rear Tie Rod and Sway Bar Links Replacement
Hey there, super helpful but I had a question I also have an STR and the parking brake caliper is blocking the room for the bolt to come out. I’ve done minor suspension work on my car but haven’t removed the EPB before. Is there an easy way to do so or a video you can share?
The JTIS manual instructs to use the special EPB software to release the parking cable and I’m hoping there’s an alternative. I would prefer not to have the hassle of retracting the pistons, bleeding the brakes, and calibrating the parking brake just to remove this bolt.
This may be naive, but Is there a simple way to remove the caliper completely without needing to detach the cable or remove the pads?
Also, it is customary to post an introduction here:
https://www.jaguarforums.com/forum/n...-intro-must-5/
Afraaz3 (07-23-2019)
I've moved your question from the end of an old thread on a related topic to a new thread.
If I remember right ......start car.....hold park brake to release position with one hand, and while holding it, turn car off and remove key....it will remain released until car is started again....I do not know if this method works with the brembo brake set up with the separate park brake caliper
joycesjag
53
11-22-2020 08:17 AM
04xtype04
05-04-2014 09:27 PM
SamOscarBrown
11-04-2013 08:16 PM
EZrider800
05-24-2012 08:16 PM
morrison
02-05-2012 06:58 AM
