Rear vents on console not working
Old 12-08-2012 | 06:49 PM
Henry's Avatar
Default Rear vents on console not working
I have a 2001 s-type and just realized that the vents on the end of the center console facing the back seats are not working at all. All other vents are working fine. Any suggestions would be much appreciated.
Thanks,
Henry
Old 12-08-2012 | 07:47 PM
abonano's Avatar
Did you try the "floor setting" on the HVAC panel - be advised the rear console vents really don't blow out to well. Another possibility - the vent hose going through the console might be disconnected at the rear vents in the console - especially evident if the console was removed to service the shifter perviously.
Old 12-08-2012 | 08:30 PM
Henry's Avatar
Abonano,
I will give it a try and get back with you. Thanks again for your help.
Henry
Old 12-09-2012 | 08:30 AM
93XJR-S's Avatar
Default RE vents
I had a similar issue was cure by replacing the servo thing for the vents and replacing the foam gaskets throughout the ac system, they had all deteriorated to dust
Old 12-09-2012 | 08:31 AM
Brutal's Avatar
floor doesnt work for rear vents. if theres no disconnection in the console youll need to close down the center dash vents to increase air flow to the rear. Its nothing more than the path of least resistance. The center dash vents have to be almost closed or closed to really increase the airflow
Old 12-09-2012 | 10:06 AM
Henry's Avatar
I will give this a try and let you know.
Thanks Brutal
Old 12-29-2012 | 01:39 PM
Henry's Avatar
I did check the vents and they are connected. I shut down the dash vents and did receive a little bit of air flow. I guess this will have to work for now.
Thanks for the information
Henry
Old 12-29-2012 | 05:46 PM
SchultzLD's Avatar
Mine was simply the flap for the vent was disconnected. (probably the kids messing with the vent too much...) Took the rear vent cover off, popped it into place, and works fine now.
johnnie ryall
10-19-2015 10:44 PM
jrbong
09-03-2015 01:54 PM
XFR_Gold
UK & Eire
09-02-2015 07:30 AM
peterg19
08-30-2015 09:48 AM
Jandreu
08-29-2015 08:31 PM
Quick Reply: Rear vents on console not working
